ship
The more correct statement is to say that a crude 2-stroke diesel such as the DeltaHawk is about on par with the most sophistiated gassers.rv6ejguy said:The SFC on a 2 stroke diesel is really not much better than a high CR gasoline engine fitted with EI and FI running LOP
apples to apples: DH vs. mag Lyco
apples to apples: subaru vs. diesel w/commonrail & EFI.
DH runs .38 using a very simple single-pulse mechanical-injection system with mechanical injection pumps...about as crude as it gets. This is deliberate. Fully electronic common-rail systems were ruled out for the first generation engines to avoid all electrical dependency FWF.
To rv6ejguy's point, the state-of-the-art gassers are using fully electronic ignition and fuel management. Under the same configuration using piezo pulse-width injectors and common rail fuel at 30,000psi, the DH should achieve SFC in the range of .33. As always, testing will tell the tale.
The current state of the art in gas is high .36's; diesels is .27-.28.
