We bought this airplane out of a salvage auction after it was destroyed in a hail storm and we have been fixing it up in between my aircraft maintenance work. It has an Aero Sport O-360 with CS BAF prop. Shown is a core O-360 to build around. New aft fuselage skin and new canopy/skirts. Used the original canopy frame. I am installing a complete Dynon system (HXD, servos, Mode
S Xpdr/ADS-B in and out. Going with the Garmin 400W that came with the plane, new Garmin 345 audio panel, New Garmin GNC 255B and an older SL30. Using the original Dynon D10A as a back up EFIS. the panel is cut and installed. All the wiring in the aft fuselage is completed. All new flight control surfaces are done using the original under structure. All wing skins are removed and the new skins are fitted. HW aux tanks on order and should be here soon. Going to keep the original paint scheme. Going to install a fuel injection kit, right now thinking about the Aero Performance kit.
