petehowell
Hello,
I have a few situations where I need to put in a connector for a number of small wires. Think bottom of the Ray Allen stick grips and behind the panel connection to the elev trim indicator. Any reason not to use crimp d-sub pins, sockets and shells with the shells held together with small nylon wraps? I secured the whole connection to structure with a larger nylon wrap.
It is a good connection, pretty cheap and easily connected/disconnected.
Seems to be a good solution, but I thought I would check with the RV Borg out there.
Pete
Pete
