I came to realize quite late that CS4-4 rivets are 120-degree ... Now it looks like I need to redo the roll bar
. I'm also searching back in the KAI to find out where I might have used the wrong countersink bit in previous sections. It would have been much nicer if Section 5 had some clear information about it.
I have to say the KAI is quite misleading - in some places it explicitly calls out for a 120-degree countersink for CS4-4, and in other places it doesn't say anything. And I somehow assumed by default #30 holes are 100 degrees. Do you guys know the rationale behind it? Is the angle only critical in some locations?
