The front plug or the one deep inside the crank?
If it is the front, get a ball peen hammer.
Put the ball against the center of the plug and smack the back of the ball peen hammer with another hammer a couple times.
This will turn the out-ee plug into an in-ee and it should come out with a magnet at this point.
Sounds brutal but it works like a charm.
I pulled it out. I drilled a 3/16 hole, but all the way through, removed the drill swarf, took an awl and punched out the remainder of the hole to keep everything clean. Screwed the tip of a slide hammer in and popped it out.
I did drill off center, but it cocked the plug and made it a little more difficult to extract. Doing again I would drill in the center.
The pre drill makes the punching very easy.
YMMV several ways to skin this cat.
Be ready, oil will pour out and there will be debris in there even if new.
I presume you meant --
I pulled it out. I drilled a 3/16 hole, but NOT all the way through, removed the drill swarf, took an awl and punched out the remainder of the hole to keep everything clean. Screwed the tip of a slide hammer in and popped it out.
Hitting two hammers together is asking for trouble. I used to think it was a load of s#!% until it happened to me (regardless of what myth busters says). While using two brick hammers (one as a chisel) to break up some old brick pavers a chunk of one hammer broke off and stuck into my thumb. A piece large enough that a pair of needle nose pliers was used for extraction. You wont see me hitting two hammers together again. Lesson learned.
I have put a self tap screw in and I'm using a slide hammer, but it is not moving. Maybe I will further dent the plug and try again. Hope that works
