COWLING SCREWS STRIPPED
After quite a few oil changes and taking the cowling off and putting back on numerous times, a few of the screws are stripped. I contacted vans to get replacements but they want to know the part numbers for the screws. I am having a hard time finding the screw part numbers for the RV-12 (everything on the top and bottom cowling). I am not the original builder. Any ideas what all the screws part numbers are along with the washers? Any help is appreciated!
Cowl screws: AN526C832R8 SS MACHINE SCREW $0.10 at Aircraft Spruce.
Washer possibly NAS1515H08L $0.03
If you need new instrument panel screws, use MS35206-228.
The heads do not strip out as easily as original screws.
Are the AN526C832R8 screws still recommended for the cowl hinge pins?
The un-threaded portion of the shank reduces wear on the cowl and enlargement of the holes (important on the RV-12 in particular since the fiberglass is not very thick).
I can see the logic, especially if the screws are not kept tight. I have 750 hours on mine with the non-shouldered screws and the cowl has no slop.
Those shouldered cad plated screws are pretty ugly on a nice paint job, I prefer stainless.
I am pretty sure that MS35206-228 are the screws that are on my instrument panel. They are not the original screws. Yours are likely different.
Did you follow the link I posted, is that the e screw you think it is?
It's possible my builder did an upgrade and countersunk the panel screws. Possibly the original kit is button head that you noted.
Seagull, plan's page 29A-11 dated 2013 calls for AN507C632R8 screws which are flat head countersunk SS.
My original plans dated 2008 call for AN515-6R8 to hold the instrument panel.
I am the only one using MS35206-228 which are an improvement over the AN515-6R8.
I had the same problem on my Long EZ and now Velocity, but they were flat head SS screws. I use a powered screw driver for putting in and taking out. In/out half a dozen times and I had to throw them away or risk not being able to get them out again.
A few years ago I switched to torx 100 deg flat head SS screws and haven't stripped one since. They do however sublimate when they impact concrete and must be replaced.
I haven't looked for pan head ones, but I am sure they are out there.
This is the screw specified in the KAI.
I have to check the KAI when I get to the hangar (apparently I've been using wrong 6 screws for the front of the upper cowl for awhile now).. but wouldn't this logic also apply to areas such as the wheel fairings (holding the two halves together).. and possibly to other areas such as: 8 screws holding on the lower cowl's nose leg plate, 4 screws holding on the lower cowl, or the screws holding on the wheel fairings to their mounting brackets?
I'm guessing that the factory just hasn't seen the wear in those areas at this time ?
McMaster has 18-8 stainless Torx round head screws.
Where'd you find the 100 degree Torx flat heads?
That guess would be correct.
You also need to keep in mind that vibration influence and other factors varies with different parts of the airframe. Screw style is a factor as well.
In cases where flush screws can be / and are used, the smooth surface of the screw head is baring on the fiberglass within the countersink. This is not the same as screw threads baring on the interior sides of an un-countersunk hole.
Another main difference with the larger wheel fairing screws is that if the fairings are installed per the plans, the brackets have a net fit to the molded in pockets on the wheel fairing that restrain movement. The primary work of the screw is to just hold the bracket in place within the pocket.
cowling screws
Scott is speaking from the factory so I am hesitant to disagree, but my KAI (p. 38-07) says AN526C832R8 and that is all I have ever used. I just had the cowling off for an oil change last week.
Washer head AN525 has an unthreaded portion of the shank and threads in bearing against the edges of a hole has always been considered ill-advised in structural design (it was specifically forbidden when I worked for the Air Force) so this type screw makes sense but that is not what is called for in my KAI. Maybe it was a revision to the KAI after I finished building?
Scott addressed the confusion in the below linked thread..
https://vansairforce.net/community/showthread.php?t=193497&page=3
screws at front of upper cowling
Scott says AN526 screws are "not what is recommended" and I don't disagree with the choice of AN525 instead, but... I have never received any communication from the factory recommending to change them. If it is important we should have received some sort of service bulletin. I think I will switch to AN525 but I have not experienced any problem yet with the AN526 screws. Live and learn.
Later: As a sanity check I just looked at the latest KAI cowling drawings posted on Van's website. RV-12 KAI, page 38-07, still says use AN526. The more recent RV-12iS KAI, page 37iS/U-12, says use AN525. I will probably change to AN525 next time I take the cowling off.
Charlie,
There is a big difference between potentially safety of flight details and a rolling product design improvement.
Many design improvements have been made over the 12+ years that the RV-12 has been active. If the design change didn’t concern flight safety, then they got disseminated via Kai revisions. Those changes aren’t done on a monthly basis so it can sometimes take a while for it to happen with an update of an overall section. This one somehow fell through the cracks but is part of our collector for that section when the next update happens.
