I have almost 8 hrs on my plane after today. I pulled the top cowl off this afternoon after the engine cooled and noticed that where my bottom and top cowl meet with the side hinges they no longer line up. My bottom cowl as sucked in about a 1/2" in the center. This is going to make it really hard to get the pins back in. It did this on both sides but the left is worse then the right.
Has this happened to anyone else and what did you do to correct the problem. I do have the inside of the cowling painted and the outside is not painted yet if that makes any difference.
