Starting a new thread so as not to totally hijack this one:
https://vansairforce.net/threads/alternatives-to-089-hinge-pin.241031/
The above discussion is about trying to fit a 0.089" diameter pin in the top cowl to firewall hinge attachment on a -12. Maybe someone has been able to help Bob solve his problem with that. In that thread I mentioned I had been able to install a full sized (1/8" nominal) pin across the top of a -6 cowl. Here's how I managed to pull it off.
The original -6 instructions for the cowl to firewall hinge attachment say to use a 0.089" diameter pin. In other words, do not use a full sized (1/8" nominal) pin, but change to an undersized approximately 3/32" diameter pin. Have to admit, my first thought was "No....I'm going to see if I can make a full sized pin work, before I give up on that idea." So, after a fair amount of trial and error fit up, it worked. Here are some tips on making this work, along with some photos.
1. Bottom cowl: side and bottom hinge pins have fully rounded over (bull nosed) ends.
2. Top cowl: hinge pins are tapered (mostly on the top side) over the last 2 -3 inches from the tip.
3. Top cowl, pilot side hinge pin: pre-bent to follow the hinge bend (sort of.....see photo below)
4. Top cowl: hinge pins do not wrap completely around the cowl curve to the end of the hinge. Pins are 2 - 3 inches shorter than the hinge.
5. Pin size: 0.117" diameter stainless steel.
