Doug Rohrer
I will soon be ready for cowl fitting on my -14A build, but my engine delivery is still four months out. I will be getting an IO-390 A3B6 Lycoming through Van's. I am wondering if I could scrounge up a O-320/360 core case and crankshaft and use this for fitting/cutting the cowl. It seems like the main factor is the distance from the rear of the engine mount ears to the front of the crankshaft flange. Does anyone know if these dimensions are the same or different for each engine size? Are there other dimensions that matter? Has anyone tried this process?
