I have failed to find the right size hunk of metal sitting in the corner to use as a bucking bar for the last two lower rivets of the side cowl hinge. I've got a pile of different pop rivets left over, but I don't know what can/should be used where. I don't have any Cherrys in the right size. Would upsizing the holes and using CS4-4's be reasonable here? My other option is to remove the engine/engine mount and just squeeze these rivets, but it would be nice if I didn't have to go that route. If the pop rivets aren't a good route to take, I'll put these rivets on hold until I can make the drive to the metal yard and pick up some stock to grind down.
