SeanB
Hello,
I'm considering installation of two Anti Splat Aero Cowl Flaps. For those of you that have installed two of them, did you also use two switches or merge into one? One fuse or separate them with two? Did you have to dig out the honeycomb material in the bottom corners of the lower cowl then do fiberglass layups?
Thanks!
Thanks!
