Post #50
The lower portion of the baffle does not fit tight against the fins. Slightly overbending the radius will help there. I know the safety wire is standard on RV's but I prefer 1/8 diameter rod with the ends threaded. Does the #3 baffle fit tightly around the oil pressure relief valve?? Another common source for leakage.
