aarvig
I wish I would've taken a picture but I didn't so I'll do my best to explain. I recently started on my project again after some time off due to moving. I had the project stored in a climate controlled ministorage. When I removed the blue vinyl from the fuel tank baffle I was surprised to see small gray splotchy marks on the flanges and the edge of the web of the baffle. Not much but there. I sanded them off with scotch brite pad and I am wondering if this is sufficient to deal with the issue. Should I replace the part? I am thinking this area will be covered in proseal at some point to so it will be hard to moniter over time. If I keep the part, since it won't be primed should I alodine it with an alodine pen or just cover it with proseal and call it go...or like asked...should I replace it?
