Both of my aileron push pull tubes have corrosion on them. One is worse than the other. I seem to remember that 10 % of the thickness is the limit before it has to be replaced. Is that correct?
They corroded under the aileron boot at the net entrance into the fuselage.
I would wager you live in a coastal location with plenty of salt air?Currently doing an annual on my RV9A, and much to my surprise it turned out my aileron push / pull tubes were severely corroded under the boots (preventing) air getting into cockpit.
I suggest you to have a look in case you have these boots fitted, especially if your tubes have not been primed
It seems the fabric inside the boot can actually hold a lot of moisture leaving the alutube in a moist environment. Tubes were not primed, but the new ones will!
I plan to have new boots made from same material as light raincoats, a good primer and finally cover the tube under the boot with heat shrink tube…..Comments pls
Any one else since 2005 who have seen this corrosion, and what measures were taken?
Lasse
FPLLE RV9A
Flying since 2017
Around 54 Nm to the sea, but as only the part of tubes under the boot is corroded I take it’s due to moisture accumulated in the fabric / synthetic leather that boots are manufactured fromI would wager you live in a coastal location with plenty of salt air?
Looking at your pictures, it appears that there are signs of corrosion on skins and ribs as well.Around 54 Nm to the sea, but as only the part of tubes under the boot is corroded I take it’s due to moisture accumulated in the fabric / synthetic leather that boots are manufactured from
