RudiGreyling
Hi Guys
I want to check your experiences.
I'm bussy assembling the center section and bolted the control coloumn and stick to it.
If I keep the control column stationary, and I move the stick forward and back, I get 1/8 - 1/4" play on top of the stick (Yellow Arrow).
The play orginate between the brass bush and the control stick housing (Red Arrow). It is NOT the bolt or bolt hole in the bush or hole in the control coloumn. It looks like the hole in the control stick bush is just too big to fit the brass bush decently?
This sounds like a lot of play to me, since it will only get worse as you add linkages all the way to the elevator.
Is this amount of play normal?
Thank You,
Kind Regards
Rudi
![control_column_play.jpg](/proxy.php?image=http%3A%2F%2Fwww.freepgs.com%2Fflyboy%2Fpictures%2Frv_forum%2Fcontrol_column_play.jpg&hash=2475d11ba57de20ce5a59b69e0c45563)
Thank You,
Kind Regards
Rudi
