I think it depends on what type of flying you mainly want to do. The RV-12 is great for local flying and some longer hops. The Rotax engine is very economical, smooth, quiet, reliable, and it uses mogas. So operating costs per hour will be less, though it will take longer to travel from A to B. RV-12 has good visibility, better than RV-9A. It is also lighter for ground handling.I have a nice 9A with 160hp engine, about 500 hours, constant speed prop , upgraded panel with Dynon HDX, autopilot.
Thinking of slowing down a little and looking at the 12 fuel injected model.
Any thoughts?
Thanks, George
I have a nice 9A with 160hp engine, about 500 hours, constant speed prop [...]
Thinking of slowing down a little [...]
Then the 9A would be a good fit, more speed, better climb, more fuel capacity, more baggage and a little less affected by bumpy air. It also is just about as good for grass and short fields. What you will miss is the modern engine, helicopter like visibility, the shoulder room, more reclined seating position, easier access and fuel economy. That is why I said a tough call. I don't do acro and I'm not into speed and I did not like the high wing loading and poor glide in my 7A (probably because of all my 9 and 12 experience), why I switched back to a 12. As I get older, I like things happening a little slower too for safety.That being said, I’m in my 30s and looking for basically the same experience I’m having now, but all the specs turned up a few notches.
my 9A oil gets lukewarm this time of the year when dialed back for slow flight (something like 130F range). Other than that it's fun to fly slow! no issue during warmer months. Can also deploy a little flap for better visibility out of the front window...I would keep my wallet shut and just pull the throttle back a couple inches!![]()
