compression tester adapter
prkaye
My compression tester has a threaded end that screws into the 18mm aviation plug hole. Does anyone make an adapter that would allow the compression tester to screw directly into an a 14mm auto-plug hole? So an adapter that has 18mm female on one side and 14mm male on the other side...
You are running Lightspeed ignition. It should be using the top plugs... 14mm.
And a mag using the 18mm plugs on the bottom. Take compression from the bottom plug holes..... far easier access.
You can make any adapter you need by just breaking out the porcelain of the plug. Remove the tip and weld on an air fitting or extension. Replace the copper washer with an "O" ring.
