Hi all,
First post for me! (Hopefully not the last).
Hoping to some day build a -9A (Starting next summer if all goes well).
For now, lots of reading and planning, and one of the first things I need to do is figure out what I'll need to accomplish this task.
Workshop? Double garage will do!
Next: Tools and equipment.
I plan on buying a tool kit. I've seen what's available, I suspect I'll go with the Cleveland one (Though I'd like feedback on ATS, not seeing much ...?).
Here in is the rub for me: These tool kits are it would appear rather incomplete. They're sheet metal tool kits only it would seem ... From my reading, there will be some wood working required (building jigs and support structures, maybe workshop tables, etc.), mechanical work (plumbing, engine, FFW type things), electrics/electronics maybe (For the panel, and a few other things), and maybe more.
So, does anyone have a more exhaustive list of what is REALLY needed to build the plane, beginning to end? If not, maybe we can build one here.
Some early thoughts:
Wood working: saws, hammers, nails, etc. Can anyone detail?
Mechanic: Might be too long to list, but planetools has kits for inspiration:
http://store-planetools.com/toolkits-mechanic.aspx
That being said, from having worked on my piper, I've discovered the list of basic tools required is not as long as one might expect ... there's a limited set of different screws and socket sizes used for example, so getting the 100+ socket kit might be over kill?
Band saw for cutting some metal pieces?
How do people mount their engine? I guess you need some device to lift it into place? Any other "lifting device" needed?
Chemical products: ProSeal, Primer, other metal treatment? Cleaning products?
Safety: Goggles, gloves, mask, anything else?
Do people use rollings islands or wheeled tool chests/trays? I've found these very useful when working on the FFW on my Piper ... not sure they're applicable when working on a airframe? (Mayb elater when doing mechanical work?)
Special lighting: Flash lights, other small lights to get into small areas?
Avionics/electrics: Crimpers, wire cutters, multi-meter, heat gun, tie wraps, heat shrink tubing, connectors of some sort ... anything else?
Vise, bench grinder?
Anyways, all this to say I think I'm going to take the ~2500$ for a tool kit and double it to 5000 for all of the above, and everything I haven't thought of yet ... sound reasonable? (Presuming new kit of course, I'm sure I could save money if I find used items ...).
Thanks!
Thanks!
