I suspect this has been discussed before, but my attempts at searching came up short. I'm starting to install my panel which includes the common wiring harness, WH-000125, that connects to the wiring harness already installed in the tailcone to the panel. I purchased this wiring harness from Stein Air with my panel. They did a beautiful job building the wiring harnesses, but I'm at a loss as to how you would route it through all the brackets, spar, etc. The holes that are provided for that purpose are simply too small to allow the connectors through and I have been meticulous in not making holes bigger or removing metal throughout the build. I want the structure to remain as strong as possible. It seems the only practical solution is to remove the connectors, route the wiring, then reinstall the connectors. Of course that comes with the risk of getting the pins in the wrong holes. Anyone care to comment on how they did this with Stein-built wiring harnesses?
