STARGATE
Member
I'm getting back into building after a life-imposed hiatus, and I'm looking for a common sense check on something I've been staring at for a bit. I've read some build logs and watched some videos and I know these steps cause some reordered parts.
I'm working on the HS front spar. The HS-00003 supplied in the kit is different than both the plans drawings and the SB diagrams (which I find more helpful than the plans/drawings for some of the items). It appears more complete, i.e. has more prepunched holes than the pictures.
As such, where the directions say to cleco the two angles and then clamp the doubler to the spar and match drill, the parts look like the angles, spar, and doublers can/should just be clecoed together then match drilled, as the holes are all already there. If I clamp the doubles aligned as directed I think I'll be adding extra overlapping holes where the angles, spar, and doublers all have holes.
1. Yes, I'm likely overthinking this.
2. Am I dumb and missing something?
Not mutually exclusive options.
Thanks everyone. This community is what is keeping me coming back to it.
