mototopo
I just finished fabricating the antenna reinforcing plates to install two Rami bent Com antenna under the seat floor.
Unfortunatelly, I initially choose to mount them in the third bay (the same bay where there is the crotch strap support) to have a nice flat rib web to rivet the doubler flange for added strengt. Only when finished I realized I don't have the 2 feet distance between the antennas as indicated on the installation manual (the actual distance is about 18 inches).
Since I haven't yet drilled the floor, I can still mount them elsewhere, but I'd like to know if the reduced distance can cause problems "in the real world".
One more doubt: if I move the antennas one bay outer, is the distance from the edge of the floor enough to provide a good ground plane?
