For those using the IO-540 Cold Air Sump with the AFP FM-200, what cable lengths worked for your throttle and mixture (push-pull, not quadrant). What brands are recommended?
Carl
Carl
What cables did you get (as in model number and such)?I measured my own length needed for my install and ordered from California push pull. I didn’t feel comfortable using someone else’s measurements due to routing differences.
Thanks Todd. What fuel manager are you using?Carl,
I'm using the Showplanes throttle and mixture brackets for the Barrett Cold Air Sump and those brackets are set up to use the Aircraft Spruce A-920 cables due to limited clearance between the bracket and oil sump. I built a custom center console for my throttle quadrant so your numbers may come out different, but all that said I'm at 67 1/4" for the throttle and 68 5/8" for the mixture.
Todd
Carl,Thanks Todd. What fuel manager are you using?
Carl
Do you have prop as well? I could use pictures, starting this soon.Carl,
It’s the FM-200A. Can send pics if you need them.
Todd
