pmccoy
I have left the bottom wing skin open, as I wanted to install some extras prior to those final rivets. Working on the fuselage, my next step calls for fitting the wings to set the incidence. I assume I should finish the bottom wing skins before doing this. I have done the following.
- Wiring conduit is run in both L & R wing.
- Auto Pilot bracket mounted in right wing.
- Pitot tube and line mounted in left wing.
So, I am asking if I have anything else to do before I close the wings. Thanks.
Pete McCoy.
Pete McCoy.
