3300-3 Answers
Diamond,
The -3 intensifier is in response to those that feel they really need to have feathering capbility with a solenoid controlled intensifier. I'll try to briefly explain the differences.
The -1 foot valve controlled unit can be made to "leak", by pressing the pedal into an intermediate position (it is very easy to do). This lets air serve both the advance and retract sides of the air piston of the intensifier, and causes the compression pin to pause in advancement. The normal condition for the -1 is for air to be directed to the retraction side of the intensifier air piston.
For the -2 it uses a single coil solenoid, which is strictly an on/off type valve, so it can not be postioned in a middle position similar to the -1 intensifier. For the -3, it has TWO 12V coils, which are independently controlled by their own switches, thus the advance and retract will only occur as long as each respective button is held.
Using the -3, you will need to depress two buttons for each rivet operation as opposed to the -2, so that is a consideration. I don't think most people really need the -3 version, but it is a flavor available. These HPRS riveters are a hair slower in operation than a pneumatic unit, and do not have quite the "pop" of a pneumatic unit, thus are more controllable.
I list a suggested electric switch from Mcmaster-Carr on the wiring drawing on my website. I don't inlcude these switches, since about any switch will work. Here are a few selections of switches for about $3-4 at radio shack that will all work:
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=switches&origkw=switches&sr=1
Wires can be as small as 28ga (2 for the -2, 4 for the -3). The solenoids in the intensifiers are low voltage and current (12V @ 500ma max). I don't want to get into switch placement, as it is impossible to satisfy all potential users preferences (e.g. - "I'm left handed" or "I'd like to use my thumb", etc.) The switch can be wire tied to the forming head, or a simple sheet metal bracket made to the users satisfaction. Antother advantage of the -2 and -3 is that the intensifiers do not need to be on the floor at all, and can be located on a workbench or from a hangar rod (suspended above the workbench like a dremel tool might be). Wiring both trigger and foot switches in parallel is possible, per my drawing.
I tried not to over or under explain this, and hope this all helps.
