Circular Connector Panel Template
Nitty
If you use the TE Connectivity circular connectors. This link (or click the image) points to the files used to layout the center and screw holes for the panel mount receptacles. Receptacles come in several sizes but I've found size 13, 17 and 23 the most useful. TE Connectivity Panel Mount Layout Template.PNG
Edit - If you go to Thingiverse.com and type in vans_aircraft, you will find several items that people have uploaded. I added several tags including vans_aircraft, vansairforce, etc based on a suggestion from somebody in this thread. Makes searching way easier.
