A10Degen I'm New Here Friend May 28, 2025 #1 I need a ruling, when I first set these I was relatively happy with what I saw, and now they are keeping me up at night. Tracking the CherryMax doc with min/max levels of flush, these are barely “unflush”…how are we feeling? I did the Vans lubrication technique.
Raymo Well Known Member May 28, 2025 #2 I don't see a problem. If you are using the correct length based on the use of the measurement tool, you should be fine.
A AZSteve053 Well Known Member May 28, 2025 #3 Some of the rivets in the pictures are questionable in my opinion, attached is the criteria I base my judgement on. Attachments Inspection Pages from Cherrymax catalog CA-1011.pdf Inspection Pages from Cherrymax catalog CA-1011.pdf 34.7 KB · Views: 57
A AlphaCharlieBravo Well Known Member Sponsor May 28, 2025 #4 The steel mandrel should be flush to the head. Did they "click" lock when pulling them? It's a very distinctive snapping sound. A Take one of the below tools (any brand) and tap it on the mandrel. If it didn't lock the mandrel will come right out. Last edited: May 28, 2025
