T Tacco Well Known Member Dec 12, 2020 #1 Do you remove blades to check mounting bolt torque during the annual inspection?
Crafting N112DR Well Known Member Dec 12, 2020 #2 Tacco said: Do you remove blades to check mounting bolt torque during the annual inspection? Click to expand... I think that depends on the prop hub that you have. My Annual is due the end of next month and I'm 92% sure off the top of my head I don't need to remove it. Subject to more research of course. Last edited: Dec 14, 2020
R RFSchaller Well Known Member Patron Dec 23, 2020 #3 I check the nut torque. Usually it’s good. Sometimes the nut turns freely and I have to open the bub to retorque.
