Checking Prop Bolt Torque at Annual
Do you remove blades to check mounting bolt torque during the annual inspection?
I think that depends on the prop hub that you have. My Annual is due the end of next month and I'm 92% sure off the top of my head I don't need to remove it. Subject to more research of course.
I check the nut torque. Usually it’s good. Sometimes the nut turns freely and I have to open the bub to retorque.
