It seems that about 40%-50% of the RVs on which I perform CI's or prebuys have the wrong bolt/nut combination on the aft spar. The aft spar actually has some movement on it during flight loads, and can move. Therefore it requires a drilled bolt, castellated nut, and cotter key. Most of the ones I see have a fiber locking nut on them. Some even have the fiber nut on the drilled bolt!
I'd post a picture but I think it is pretty self-explanatory. Most of the RV's can be checked with a flashlight by crawling underneath and looking past the flap. It is also very easy to remove the last two screws on the wing root fairing and peel it back to inspect.
Vic
Vic
