dan carley
Does anyone have or know where to get a
good checklist for the rv7 ?
Thank you
Danny carley
Thank you
Danny carley
I like it, it’s a good start, but it’s still a bit complex and could be simplified further.Preflight: All big pieces attached
Starting: Start
Before Taxi: All switches on
Before Takeoff: Line up, all levers forward
Flying: Push forward, houses get big
Pull back, houses get small
Pull back more, houses get big again
Before Landing: Big lever back
Shutdown: Everything off
Ideally, checklist and panel layout are designed at the same time. Don't copy somebody else's checklist. Write your own that gives good flow around the cockpit as you perform the checklist.
Well, shoot. Tried to post pics of my checklist but it doesn’t work. I copied and pasted the URL to the pic on Flickr into the Insert Image link but it isn’t working.
How did you do that? Pretend for a minute that I am baffled by the sorcery of anything more complex than an iPhone (not much of a reach, actually), and walk me through how to make the checklist visible here.Here is your pic using your Flickr .jpg file:
There are lots of philosophies on what should and should not go into checklists. One standard fallacy is to put everything possible on the checklist. This subject would make a good article, and I'm pretty sure i wrote at least one in the past. Don't know if I can find one, though...
