For the more experienced builders doing a -15, is it necessary to check the fit of assembly before primer or not? Did you do it, should I do it, or does everything go together so well it's not really necessary? Thanks for the opinions.
I didn't check fitments, but I also didn't prime more than the essentials. The only fit problem that I had was the elevator piece that was incorrectly punched and that shouldn't be a problem if you aren't in the first 10 tail kits. Fitment has been spectacularly good on the wing and tail kits.
