The fuel regulator replacement isn’t new, but eliminating the fuel-line hoses is. The short hoses connecting the fuel pumps and bypass valves in the fuel-pump assembly are the only ones we have in the iS, so makes you wonder if that’s an omission error?
Note they also added the rubber pad under the coolant-expansion tank. Lockwood mentioned that one during their maintenance class, so looks like Rotax is acknowledging that too. Rotax apparently isn’t too conscientious about using the revision bar to highlight additions, since they sneaked the expansion-tank pad in there without highlighting it. Makes you wonder what else got added?
