When building an RV7 (not 7A) is it more likely that you will end up with an aircraft with C of G tending forward or aft? I know there are a million variations, but presumably there is a tendency to end up at end of build more one way or the other. I am thinking of whether the tendency would influence if you would want to have a CS prop, whether you may place battery on firewall or further aft. There may be no problem at all. There may be a lot of different solutions.
Unfortunately a search of "C of G RV7 is rejected by search engine.
John
John
