Hi All,
This is quite a start as my first post on VAF... I had recently purchased a RV-7A. It was noted to have consumed some oil (1 quart/6-7 hours) by its previous owner. It has an Aerosport Power O-360 A1A, and the aircraft/engine is fairly high-time, having 1055 hours in total. The engine had been IRAN'ed early in its lifespan due to a stall/spin accident which had resulted in a propstrike, followed by cylinder removal at ~825 hours due to rough running (which turned out was actually due to a bad Lightspeed coil pack). The cylinder work was done locally by a mechanic who is no longer working.
On pre-purchase inspection the oil was relatively clean after 20 hours, the plugs were not oily, and the filter was also looked good. I assumed that this oil consumption was reasonable and had flown it ~30 hours since purchase.
Unfortunately the oil consumption had continued to increase, and had reached a quart every 3-4 hours. I had also found significant oil on the belly of the aircraft, but no leak at rest. I evaluated this with the help of my local A/P as the aircraft was due for condition inspection at that time anyways.
We ultimately determined that there was significant oil leak from front case seam, with considerable oil on the top of the airbox. It was also found that the at least one of the cylinder case studs, and one of the thru-bolts, was loose as well.
My mechanic reports that he has seen some Lycomings suffer case leaks, and still be airworthy, although we both agreed that rectifying this would require a case split/reseal. He retorqued the loose studs in question.
I am admittedly rather uncomfortable though about continuing to fly the aircraft in the setting of the loose thru-bolt/case studs, and have grounded it. My current plan is to get it professionally IRAN'ed with case resealing at this time. Is this over-reaction on my part? An oil leak is one thing, but the loose studs after cylinder work make me much more worried about a potential bottom end issue.
The engine work will be done at Penn-Yan mainly due to proximity.
