backcountry
I’m having problems with the finish on the inside of the carburetor Bowls flaking off. Sometimes the engine goes very rough and I have to reduce power and it’s not enough to stay in the air sometimes. Then I pull the bowls from the carburetors find this flakes in the bottom of the bowls and I clean them up and the engine runs fine again. The problem is it returns again as the flaking continues.
The finish on the inside of the bowls are bubbled up as it looks to be corrosion underneath the finish. My guess is it’s caused by ethanol fuel.
I’m looking for good source to replace these bows with new ones as I’m afraid to use the old ones any longer.
