Carbon Fiber on Main gear fairings?
daddyman
I'm at the point in my build that I'm about to do the main gear leg fairings.
The plans call for wood/foam with aluminum over, or all foam with fiberglass over.
I am wondering if anyone has used carbon fiber?
It is not for the strength or rigidity which would be a bonus, but instead because I have so much of it "laying" around.
OK, I also think it looks cool.
Is there a reason why I should not do this?
Also, is there a good reason not to use a single outer structure instead of the 2-part as the plans call for?
Thanks in advance for your thoughts.
Daddyman
Carbon works
I wrapped my Rv3b legs with carbon instead of hinged fairings to get the forward /aft stiffness with one component instead of two ( stiffener + fairing).
It worked very well. Mycool has the Rv now so contact him to get his input.
Send me your email for fab pics if desired. [email protected]/ text 7655051160 for discussion. Also, Rocket Bob has a thread on Carbon wrap for stiffness.
Stiffener
There's a thread about stiffeners by Paul Dye. You could use a piece of carbon fiber instead of the .125 aluminum.
No idea how it would perform. Maybe one of the super-duper Engineers can run the numbers.
You might wait until you find out if you need them before going to all that trouble.
I postponed making the stiffeners and found out that, in my case, they aren't needed..
