Thank you,
Do you also dip the soft in epoxy or something to prevent corrosion in them? Can epoxy alone be used to hold the nut plates?
It would have to hold the 2 cowl half's together... I would think that as long as the nut plate stays on to screw into - it would be fine...?...
Thanks again,
