I am facing the same question. Another suggestion I have heard is to use the passenger side stick to break out the canopy. Not too sure how tough that would be to bust out of in a really bad situation with very limited time. I would need an hour or two for that myself... A shotgun rather than a short metal tube would probably be a little more efficient at knocking the canopy out in a panicked hurry although I'd probably shoot myself in the process.
I'm leaning to forego the canopy jettison because as I currently see it....
A) It has not been tested/used successfully to my knowledge.
B)After phase 1 when you re-install the gas struts, the jettison handle appears as useless/impractical to me. Removing the gas struts for phase 1 also makes me wonder how easy it would be to egress during an on ground fire, etc. Can anyone discuss the handling forces involved on a canopy without the gas struts? Is this an easy one man job to get out from under it?
C) I look at the majority of issues being engine outs rather than uncontrollable flight or inflight breakup. The terrain in which I live provides a lot of landing options although I'd prefer to have several square miles of smooth manicured concrete in all directions below me.
D) I'll perform careful weight and balance calculations, preflights, etc and do everything I can to minimize the chances for an emergency including adequate transition training in a 7A.
E) I'll say a prayer before every flight. If it goes bad after that, you know the rest of the story.
Okay, the above is a bunch of my hot air. This is just my opinion of things as I currently see it and nothing more. I am always open to wisdom and will stand corrected if it makes sense to me.
I do have a serious follow up question because I honestly do not know the answer. Has anyone ever had to bail out of an RV-7/7A tip up while in flight? If so, were they successful in doing it?
