Canopy Frame
AJBENKER
Member
I installed the canopy frame on my 12 just as directed. I used the wood spacer blocks to hold the rear frame to the roll bar. I put the bubble on and did the necessary trimming and proceeded to drill the holes for and aft. When I got to the point of removing the spacer blocks and clamps so I could tilt the canopy forward things changed. The canopy frame twisted not allowing me to raise it up and forward. The plexiglass is hitting on the pilot side. Should I remove the bubble and trim the forward portion of the bubble? Help. Thanks everyone.
I don't remember this step to be all too difficult and there was not more than a slight warp in my frame before I put the bubble on. Could you post a picture of the misalignment? That might give us a better idea of the interference...
All is well. Thanks for the help. I just didn't trim the forward portion enough. Everyone who has worked with the bubble understands the caution involved. I was being overly cautious.
