Scott Will
It always happens at the last hole, doesn't it? I apologize in advance if this post goes long! I have 3 issues and looking for the best way to proceed. We'll start here:
There are two things, the crack and the bad edge distance in the plexi on the other holes. The crack happened when the plexi bit got stuck - tried to free it but to no avail.
And when it was all said and done, my perflectly flush canopy in the front lifted up:
So how to proceeed?
I'm not sure why Van's uses screws - probably because the rivets expand and put a radial stress on the canopy? But how does that explain the RV-8?
Thanks for the advice in advance!!
![img_6723.jpg](/proxy.php?image=http%3A%2F%2Frv7a.home.comcast.net%2Flog%2Fimg%2Fimg_6723.jpg&hash=3655b97874ee25a6107a862c36dcb575)
![img_6725.jpg](/proxy.php?image=http%3A%2F%2Frv7a.home.comcast.net%2Flog%2Fimg%2Fimg_6725.jpg&hash=a49691b0b40716b11be34c195d373235)
So how to proceeed?
- Obviously the crack has to be removed - I assume just scallop it out.
- About the edge distance - after countersinking the edge of the countersink will be at the edge of the plexi or a tad beyond it in certain placed. I had to trim the plexi sides to make it lie flush with the joggle. What do I do about this?
- How about using CS4-4 pop rivets instead of screws? The CS4-4 rivets are used on the RV-8 and use a much smaller countersink
- How about drilling new holes between my existing holes? The new holes would be higher and allow for better edge distance PLUS at the same time perhaps we could ensure the front of the canopy is flush with the front while we re-drill.
- Leave as is - countersink and maybe use some adhesive (ProSeal or Sikaflex) along the sides and front to take up most of the stresses?
- Put clips on the front to hold the canopy down. It can be held down as it is with little pressure.
