bsbarnes10
Active Member
Hi All,
I'm working on installing the side skins on page 23iS/U-07 (rev. 0) of the KAI. In step 7 it says to "Rivet...F-01234-L-1 & -R-1 to the fuselage as shown."
In figure 1, on the right side of the fuselage there is a dotted box which identifies an area where CS4-4 rivets are to be used to attach the canopy deck (F-01234-R-1) to the longeron (F-01255-R-1). There are also three rivet holes which are marked with triangles, indicating that they are to be left open. The remaining holes on F-01234-R-1 do not indicate the rivet type and I couldn't find anywhere else in Figure 1 where it is called out, or on page 23iS/U-10 Figure 1 (which has the callouts for the side skins). Usually there is a "LP4-3 typical except where called out" or similar notation but I don't see any here...
I don't believe these holes should be left empty because they're not marked that way and if I had to guess I'd assume they are LP4-3 rivets but maybe I'm missing something?
Any ideas?
Bruce
Any ideas?
Bruce
