Steve12385
I'm New Here
Was trying to get the cotter pins on the castle nuts that mount the engine to the engine mount with some not so good results. Then I notice now days the plans call for metal lock nuts. So my question is can i use a metal lock nut with a drilled bolt ? Or should i change out the bolts if i decide to use the metal lock nuts. thanks, steve
