I want to check cylinders and valves. Anyone have good tips. Want to spend $100 or less. Thanks
OK thanks... I was thinking $70 to $100, with camera and screen... no need to break out the phone or laptop.Choose cheap or good, not both.
I bought a Teslong articulating borescope from Amazon for $118 bucks last June to use for my condition inspection. It can record images, has a slim probe so you can get it through small tooling holes, a lighted articulating arm and easy to view screen, plus you can recharge the battery via USB. I've been very happy with it.I want to check cylinders and valves. Anyone have good tips. Want to spend $100 or less. Thanks
I have same one works great.I bought a Teslong articulating borescope from Amazon for $118 bucks last June to use for my condition inspection. It can record images, has a slim probe so you can get it through small tooling holes, a lighted articulating arm and easy to view screen, plus you can recharge the battery via USB. I've been very happy with it.
I probably use it more at home than in the hangar. It's great for in-wall wiring projects. I recently used it for running a new water line to the fridge, and just yesterday used it to retrieve an AirPod that the cat knocked under the refrigerator.I have the Vividia VA-400, but the Vevor model described in post #3 is much, much easier to use. And less expensive.
The Vevor is a game changer for doing inspections also - looking for cracks and other important things in areas one could normally not see.
I got the tip for this scope from MacCool - thanks Howard!
Vevor’s standard articulating endoscope will flex 180°, but in only one plane. Their 360° articulating endoscope will flex in multiple planes. That kind of steerability and flexibility is everything in fiber optic endoscopy. Especially given the price differential, there’s absolutely no question in my mind that I would buy the newer 360° version. Not to mention that they have almost certainly improved the optics and video processing.Does anyone have this 360 degree version of the Vervor? 360 Vervor
Im not sure what the 360 does over the standard flex head but only a few more bucks.
+1. I like it.I have a Teslong Two-Way Articulating Borescope, 5.5mm Slim Probe and love it.
The slim probe really makes a difference in certain use cases.
It recently failed after 10 months, I was getting the no camera error. But Teslong warranty / customer service is great and they sent me a new unit.
+1. Very good value. Amazing what you can get these days. I bought an 8' Olympus articulated fiberscope in ~1995. I think I (the company) paid $20k for it.+1. I like it.
I still have and use my rigid Olympus, all glass (no camera) best optics ever!+1. Very good value. Amazing what you can get these days. I bought an 8' Olympus articulated fiberscope in ~1995. I think I (the company) paid $20k for it.
Do you have a link to this borescope on Amazon or can you tell me the manufacturer and model?I went with Amazon's TOP choice and was just under $80.... I LOVE IT... It even came with a 32 Gb SD card to record video and pictures.
I am closing up bottom of wing, and mirrors and flashlight are great, BUT.... It is TOO GOOD (kidding), but any defect, tiny mark on shop head, not square set, or a small scratch on nearby structure from bucking bar, it can look huge... Mirror and flashlight it looks 100%. It has x1, x2, x4, x8 zoom.
I struggled with a cheap USB on phone cameral. Being cheap, good enough. I thought bore scopes were $1000's and they can be. The real cheap solution, no articulation and camera plugged into phone on the end of a floppy cable not great. I did that, used tape to attach solid bare 14 AWG copper wire to camera cable so I could extended it into tight areas, and bend when working on car. Did a timing belt change. Dropped hardware into bowls of the engine bay. I found it, but not easy. Alignment of timing marks also a the camera came in handy.
- I ended up drilling out 3 defective rivets. Keep in mind when bucking these they are by feel.
- Two rivets too short. Dwg says -4, but -4.5 better. May be short ones mixed in? Replaced.
- Another 4 or so were under set, and needed further setting.
- Best to get them while you can before they become inaccessible.
- Wanted this tool* to also check cylinders/valves, accessory gears.
Dedicated camera, flexible cable, articulation,, screen with handle and controls, to zoom, rotate, record (video and pic) is far better. Perfect? Well you have to do some mental orientation, but that is operator skill issue.... Is the camera top notch Olympus or an arthroscopic surgery camera? No, but for under $100 the images are very good. Why I did not buy one sooner I don't know. It also came with carry case. Really great value. Not trying to sell anyone. Just happy I got it, and I don't have half dozen sub par rivets in my wing.
Thanks!
Thanks, Jackking123. I think this might work for me, too. This thread has lots of great choices!LumenScope Articulating Borescope Camera with Light,Two-Way Industrial Endoscope Inspection Camera with 0.24In Articulated Probe, 5.3FT Flexible Snake Bore Scope Cam for Automotive Engine Inspect: Amazon.com: Industrial & Scientific
LumenScope Articulating Borescope Camera with Light,Two-Way Industrial Endoscope Inspection Camera with 0.24In Articulated Probe, 5.3FT Flexible Snake Bore Scope Cam for Automotive Engine Inspect: Amazon.com: Industrial & Scientificwww.amazon.com
LumenScope Articulating Borescope Camera with Light,Two-Way Industrial Endoscope Inspection Camera with 0.24In Articulated Probe, 5.3FT Flexible Snake Bore Scope Cam for Automotive Engine Inspect.
For the money I like. mburch post #19 looks like the camera can bend in all directions, he says on sale sub $250. Mine only goes in two directions, which I do find useful. I think what I have will serve me well.
This is an excellent unit. was just on sale for $130
Impressive qualityThis is an excellent unit. was just on sale for $130
It would be very good provided the steering has some sort of friction which holds it in position. If it springs back to center when the joy stick is released it would not be good.Does anyone have this 360 degree version of the Vervor? 360 Vervor
I have that same model I got on Amazon and its been great to use! Highly recommend and the picture quality is very good.I bought a Teslong articulating borescope from Amazon for $118 bucks last June to use for my condition inspection. It can record images, has a slim probe so you can get it through small tooling holes, a lighted articulating arm and easy to view screen, plus you can recharge the battery via USB. I've been very happy with it.
