I'm replacing a Concorde RG25 X/C battery with an EarthX900. The weight delta is 18.6 lb, and with the battery located several inches behind the rear bulkhead, the CG change won't be small enough to ignore. I'd like to generate new W&B paperwork by calculation rather than re-weighing. The process to do so is straightforward, but I can't seem to find information showing the ARM at the center of the battery tray. Clearly a lot of other RV-10 owners have switched from AGM to LiFePO4 before me. I'm hoping that those who have done so have the ARM info. I have tried contacting tech support at the Mothership during telephone hours, but thus far haven't gotten through.
