Okay, I'm working on finishing up the engine compartment details. Van's says the inlet duct for cabin heat is on the left front floor baffle. The heat muff is mounted on the right tail pipe. I looked at how the scat would run around the front of the engine cross over exhaust, some how past the alternator, down the right side of the engine (next to the exhaust stacks) and finally connect to the heat muff. I mounted the inlet on the right rear baffle and straight down to the heat muff.
Any thoughts or experiances out there? Does it degradate engine cooling with the loss of air at the rear of the "plenum"? I've seen it done this way on many other airplanes.
Going to the hangar for final assembly in two weeks!
