Jim P
I'm taking a shot here for some help. I'm getting towards the end of Phase 1 and I installed a fiberglass targa strip to the tip-up canopy. After it was bonded, the canopy is tight to close and appears to seal very well. That's good. The bad part is the that now I have a nice loud air leak. I suspect that I've had one, but the air coming in = the leaks around the tipper aft adge and I didn't get the noise, but with that closed up, I'm thinking I now have a leak on the forward edge causing the noise. It doesn't seem to vary with vent open/ closed. Any hints to track down the culprit? I'm heading to the aviation aisle at the locak Home Depot for some weather stripping to tighten up the any gaps.
