Robb,I snapped an an3 bolt off in a nutplate. I only have access to the entry side of the nutplate and main wing spare web. I was attaching the bellcrank brackets. How can I remove it with out distroying everything around it?
Robb....7A
an extractor wth a built in left hand drill bit. You just run the drill in reverse and start drilling. Most of the time the bolt will start backing out before the extractor engages. They are perfect for small bolts. Just be sure to drill the center.
