I don't undersdand how to tighten/seal the brass elbows for the brake master cylinders. I bought bakerseal as suggested by some on this list. (Thanks Dan) I painted the threads of the brass elbows. I threaded the elbows into the master cylinders.
I cannot make them "tight" and properly positioned to attach to the tubing. If I loosen it a little so that the proper orientation can be made then to fitting is too loose and sort of flops around when the pedals are moved.
What am I missing here????
Duane
Duane
