yankee-flyer
I called MATCO and they recommended Loctite 567 (Teflon) sealant. I removed every brake fitting from the bleeders up, cleaned off the old sealant (brake fluid turned it into something very hard!) and reinstalled all fittings with 567. Not a hint of seepage after 3+ hours of use. If you have't gotten to the brakes use this stuff the first time as getting all those elbows off (and back on) with everything inside the airplane is a real pain-- as in shed blood working on the fittings inside the fuselage.
Wayne 120241/143WM
Wayne 120241/143WM
