The o-ring seals in my wheel calipers (Matco) are the standard ones, (MS28775-222). They have 1600 hours on them and as preventative maintenance I decided the change them per SL-00047. I have the high temp ones from Van’s, (U-00025) Viton. When I installed them they leak.
I reinstalled several times and no joy, still leak. I put the old ones back in and the leak stops. I have (4) of the high temp Van’s ones and they all leak. I tried both left and right caliper with the same results. The o-ring dimensions are identical to the old ones.
Any idea what is going on?
